09-29-2016 01:22 PM
57 123
tools
  1. Snareman's Avatar
    Sorry... What does switching it to timeout accomplish? Which btw I can't see that option.
    Right. That's why I listed the steps. Setting to screen timeout is the same as letting the screen time out to the normal 30 or 60 seconds you have it set to where ur doesn't lock the phone in a way you need the pin for. But it does it in a few seconds instead of 30. You need to sign up for Nova Beta before you can see that option. Figured this all out from the last 2 pages of that Thread I posted the link to.
    09-24-2016 09:09 PM
  2. Dhawk1202's Avatar
    I appreciate the help. I'm on 5.0 beta. Which it's telling me it up to date, and I've updated all I can. Still not seeing the setting. I've been on beta for awhile. Getting excited for a fix lol.
    09-24-2016 09:14 PM
  3. Snareman's Avatar
    I'm on 5 beta 4
    All the way at the bottom under advanced features there is the choice of lock method. Click on that. I'd post a picture of it but can't figure out how to do it from my phone
    09-24-2016 09:20 PM
  4. trucksmoveamerica#AC's Avatar
    I'm on 5 beta 4
    I have same version and don't have that option.
    09-24-2016 09:37 PM
  5. Snareman's Avatar
    Do you both have nova prime?
    09-24-2016 09:43 PM
  6. Snareman's Avatar
    09-24-2016 09:43 PM
  7. Snareman's Avatar
    09-24-2016 09:52 PM
  8. trucksmoveamerica#AC's Avatar
    Don't have that option on mine.
    09-24-2016 10:04 PM
  9. trucksmoveamerica#AC's Avatar
    I do
    09-24-2016 10:05 PM
  10. Snareman's Avatar
    So you don't have an option below aggressive desktop? Odd
    09-24-2016 10:41 PM
  11. trucksmoveamerica#AC's Avatar
    No I don't. That is odd. Wonder if something else needs to be turned on to get that. Don't know
    09-24-2016 10:49 PM
  12. Snareman's Avatar
    You should write to nova guy and ask him. He is usually pretty responsive.
    09-24-2016 10:55 PM
  13. Snareman's Avatar
    I don't know if this would make a difference or not but under the double tap gesture I set it to the Nova screen off instead of to the app that I was using
    09-24-2016 11:00 PM
  14. Snareman's Avatar
    09-24-2016 11:04 PM
  15. trucksmoveamerica#AC's Avatar
    I don't know if this would make a difference or not but under the double tap gesture I said it to the Nova screen often instead of to the app that I was using
    Tried, made no difference.
    09-24-2016 11:10 PM
  16. Dhawk1202's Avatar
    Yep. I have prime too. Weird. Oh well thanks for heads up. I'll keep trying.
    09-25-2016 12:26 AM
  17. Snareman's Avatar
    Let me know if either of you figure something out. Usually I'm the odd man out. Maybe refer the Nova guy to this thread so he can see the differences?
    09-25-2016 10:19 AM
  18. trucksmoveamerica#AC's Avatar
    I just sent developer an email and link to this forum. Will see what happens.
    09-25-2016 10:29 AM
  19. trucksmoveamerica#AC's Avatar
    I'm also assuming everyone is using a note 7 also.
    09-25-2016 10:54 AM
  20. Snareman's Avatar
    I'd assume so since this is a Note7 forum, but I'd think that it should ideally apply to all phones with an up to date OS.
    09-25-2016 11:12 AM
  21. trucksmoveamerica#AC's Avatar
    I got a reply from the developer. Here it is, I now have it and double tap for screen off and using fingerprint to unlock is working.
    09-25-2016 12:05 PM
  22. Snareman's Avatar
    Glad you got it to work.
    09-25-2016 06:25 PM
  23. steezytech's Avatar
    nova gestures wont work. sorry
    09-25-2016 11:29 PM
  24. trucksmoveamerica#AC's Avatar
    I use mine every day. Swipe up, swipe down, double tap. They work just fine.
    larry1014 likes this.
    09-26-2016 07:31 AM
  25. Snareman's Avatar
    Some here
    09-26-2016 07:47 AM
57 123
  1. What Will It Take For The Ban Of The Note 7 To Be Lifted?
    By Bartone in forum Samsung Galaxy Note 7
    Last Post: 09-30-2016, 12:23 PM
  2. How to change the screen over lock screen
    By AC Question in forum Samsung Galaxy S7
    Last Post: 09-27-2016, 06:03 AM
  3. Audio Settings for headphone jack
    By homer813 in forum Samsung Galaxy Note 7
    Last Post: 09-26-2016, 12:13 AM
  4. Best Way To Back Up for Replacement
    By komobu in forum Samsung Galaxy Note 7
    Last Post: 09-24-2016, 03:52 PM
  5. Replies: 0
    Last Post: 09-24-2016, 01:12 PM
