Fingerprint lock always asks for PIN
Snareman
2,356
33
48
Let me know if either of you figure something out. Usually I'm the odd man out. Maybe refer the Nova guy to this thread so he can see the differences?
trucksmoveamerica#AC
Trusted Member
Jul 20, 2010
8,071
660
113
I got a reply from the developer. Here it is, I now have it and double tap for screen off and using fingerprint to unlock is working.
Yep. I have prime too. Weird. Oh well thanks for heads up. I'll keep trying.
Bbarbie
312
My phone used to lock after not being used and then ask for fingerprint but ever since I set up my new fitbit it won't lock at all... I use Samsung s view case and it locked before but not now. What is causing this ?
Snareman
2,356
33
48
Did you set up the fitbit as a "safe connection" or whatever its called where the phone won't lock while connected to it? Turn off the FB or disconnect it from the phone and see if it locks then.
Bbarbie
312
Thanks again your trick helped solve my issue. I wonder if the always open when fitbit is around setting caused battery to drain ? Because before that i had no issues with battery loss. I shall observe how it works now that I fixed the issue. Thanks again.
Snareman
2,356
33
48
Glad it worked. Not sure about the FB. You could take it away and see if it changes things.
smokedog87
