how are you able to post screen shots ?
I use the Tapatalk app. I usually post my comments from my phone.
After some more testing I've managed to get even more use out of the phone. I've been testing turning off none essential features in the phone and managed to get close to 6hrs screen on time and a full day usage. 3% battery left. Turning off NFC and AOD really helps increase battery life. I don't mind turning off NFC as I don't use Samsung Pay that often or anything that uses NFC but I still want to find a way to keep AOD on, keeping WQHD+ resolution as well and get great battery life. More testing will be done. I'll keep posting my results here. //uploads.tapatalk-cdn.com/20171114/0589a9b31b316cc322e2b0cc8df7da20.jpg//uploads.tapatalk-cdn.com/20171114/017eee06cdc1b838186d6f0c12f928e5.jpg
From the starting post you got 9 hrs of OST. Now you get only under 6 hrs?
as said a few posts above, if you have bad phone signal and/or wifi it will affect your battery life., I have good of both, wifi, mobile data, aod, always on, using performance mode only, few hours of music every day and I'm pushing 7-9 hours on screen time, I don't keep it to bright though, my phone never gets under 30% so sometime I must try a real push to see.
I am getting the impression that the exynos is better at power management
Last night, I did an experiment. I turned off mobile data over night and only left on Wi-Fi and Bluetooth. Went to bed at 11pm with 100% and woke up with 75% at 6am. For simple standby, is this not a rather high battery drain?
Exynos is usually more Power Efficient than Snapdragon.as said a few posts above, if you have bad phone signal and/or wifi it will affect your battery life., I have good of both, wifi, mobile data, aod, always on, using performance mode only, few hours of music every day and I'm pushing 7-9 hours on screen time, I don't keep it to bright though, my phone never gets under 30% so sometime I must try a real push to see.
As a quick update, took the phone to a Samsung Service centre and after running a few diagnostics, I was told that both phone and battery are perfectly fine and that I'm not eligible for a replacement of either. Very odd...
