Do you think Samsung will ever bring back the classic SNote like we had before the Note 8? I'm using a apk file that someone put up on YouTube. I didn't like what they did to the SNotes on the Note 8.
TBH, I don't think S Note will come back. I wish it did. I don't like the new Samsung Notes. As far as action memo, this is the closest you'll get for now.
https://forums.androidcentral.com/e...n-samsung-notes-action-link%2F&token=0NkzO6R-
Someone also made an app that allows you to choose a handful of templates. You're right tho that earlier versions had way more, way better (and in portrait and landscape layouts).... S Notes also had templates (although they were better in earlier versions).
A while back I started saving a bunch from my Notes 3, 4, and 5, but never finished. If you have access to any of those phones you can open a new S Note file, add a few additional pages, then save it. Duplicate each template as you need them so you always have a blank original. (Someday I'll continue that since all those phones are still in my family.)
https://play.google.com/store/apps/details?id=getwings.com.snotetemplates
Samsung Notes is the watered down version of S Note that first was installed on the Note 7. S Note, from a few years ago, is a rich, full-featured productivity tool. However, the version of S Note offered in both the Google Play store & Galaxy App store no longer has Action Memo as part of it.I see Samsung Notes and S Note in Galaxy apps. What is difference in the apps?
Wow. So if you same the template, you can carry it over to the new note?
So long as you're using the versions of S Note and the extensions linked to above.
