Loud speaker or earpiece speakers for calls?How loud is the speaker on the note 9 to you? Mines is pretty low.
Mine is good , maybe some build up in earpiece speaker can try to clean with a toothbrush see anything build up there , also if you long press in notifications drop do menu Dolby Atmos in the settings it by default auto can try and set for voice see if that helpsEarpiece, my bad. I can barely hear my phone on the speaker.
Thank you, I use the thin spigen caseI'm see right now, thanks for the advice. Phone is boring but reliable. So cd you good with advice do you have a wireless car charger in your car? Does your phone have a problem charging with it? My phone goes on and off wireless charging seems like the case is the issue. The phone works without the charger.
Still trying to fix happiness with this phone. What case you have by the way?
Oh ok , definitely can get another. Your welcome!It's the car charger that cuts in and out, probably should be thrown to the bushes. Thanks for the response.
