Is it possible to get WiFi calling toggle into Quick Settings?
Which Carrier your on ?Is it possible to get WiFi calling toggle into Quick Settings?
It's possible they haven't added it yet.Verizon.
It's not there.
Once you set WiFi or cellular it should.Speaking of similar, is it possible to disable the repetitive and annoying notification: “WiFi calling settings updated”?
I see , gotchaSpeaking of similar, is it possible to disable the repetitive and annoying notification: “WiFi calling settings updated”?
I think you misunderstood me. I've set it already and it still keeps sending me a notification. Otherwise, I wouldn't have asked .
I see , gotcha
I'm not sure why it would keep giving notification once you choose . Do you have it set WiFi or cellular?
Doesn’t matter. It occurs with either setting .
Look in your phone dialer app in settings of it if you see the toggle there?View attachment 305652
What's the advantage of toggling wifi calling to off?
It's in my dialer settings. I want it in quick settings.
That's what I mean if it's there, should be a toggle in notification panelIt's in my dialer settings. I want it in quick settings.
Can you , what's the command for that?Can adb command and add that wifi calling toggle.
