Is there a biiig cursor to use with the s mouse when in hancom word?????
Nychotxxx
465
7
I was using the one big cursor app i found in the playstore and it worked fine until Hancom Word updated and now its that same old thin, hardly visible vertical line, yet the app's big cursor works in other applications. as someone writing often I really need a bigger cursor. any ideas?
bpeter
49
Have you tried uninstalling the program (big cursor app), rebooting, and then reinstalling the app? I have had some weirdness pop up after updates but uninstalling and then reloading programs seems to slick out any problems. (You may also want to try clearing the cache during the reboot.)
Nychotxxx
465
7
Yep I did uninstall and reinstalled, but no luck. Do you use big cursor with hancom word? Btw, which cache are you referring to?
Tnx
smokedog87
