Hi, I'm new here and hoping to get some help. I've had a Samsung note for about 2 months, and still trying to learn how to use it.
I was having issues going through a lot of data compared to my iPhone, and purchased an app called Ad Blocker. This cut out the ads, which was great.
However, I just started to notice (it's probably been doing this for a while and I just realized it) that when we use the apps, it switches from wifi to 4g. We're usually at home and always using Wifi while at home, so I can't figure out what setting is making it default to 4g while in an app. What do I need to fix?
Also, I notice it doesn't automatically connect to wifi when I'm home. I have to manually connect to wifi or the 4g shows. Do I have a setting wrong?
Any help you can provide would be great.
Thanks!
Thanks!
