Hey guys. I have two questions for ya.
There seems to be various opinions on how to properly charge the battery when you first get the S2.
I seem to here two ways:
1) Charge the battery fully (maybe a good 8 hours? Anyone have a good value?) BEFORE first usage. Then you can go ahead and use it. <--- I was taught this way back the early millenium with all the new fancy cell phones.
OR
2) I assume there is probably going to be somewhere between 50-80% of battery life before you even put the battery into the phone. Thus, one should use up the battery until it drains completely. Then recharge it back up to full again. And vice versa.
Which is the correct method of choice as far as preserving battery life? Does it even matter?
My second question deals with whether an adapter for the battery charger would be okay. Like many of those who live in the states, we have to import the S2. I bought mine from Expansys-USA, which gave me a UK/European model adapter and then a generic converter (for converting UK/Europe to US/North America). Anyone know if this is okay for the phone or battery? It seems like there would be an "extra barrier" to prevent the phone from charging 100% accurately or properly. I do not know too much about electrical engineering, but it just feels like the Europe-to-NA adapter is acting as a sandwich between the phone and the outlet.
Should I go as far as buying an adapter from Canada (if they have one available) to ensure maximum charging compatibility?
OR
