This scanner has a huge learning curve. So far I can only get it to work 50% of the time with one thumb. The other 3 don't work at all. Good Luck.
My phone is on the way so I can't test quite yet. But I've heard having the phone learn the same finger 2 or 3 times helps.
Like running the test 2 or 3 times you mean?? Each test is a series of presses if I'm not mistaken.
I believe he means to scan the same finger multiple times. So if you only use your thumb to unlock, save your thumb twice or as multiple fingers to improve recognition.
So when you save your finger print with Samsung it only asks you to press once and not a few times?
**edit** I'll figure it out, lol!
They mean that you should register your thumb as 'finger 1', then register it again as 'finger 2'. You can register up to four fingers, so you could register your thumb twice more if you wanted.
Mine came with plastic over the front but no obvious way to take it off. The plastic on the back had an obvious tab to pull. I cannot get my fingerprint sensor to set up. It tells me all the time to press harder or to cover the entire sensor with my finger. Does this plastic on the front need to be removed first, or is this a screen protector that can stay in place? There is a hole in the plastic where the selfie cameras are, but no hole by the fingerprint sensor like the one I have seen on at least one unboxing video.
It is a screen protector. I have heard mixed things so far on if it is affecting the sensor. It shouldn't as these are installed on every phone, but guess we will see. I will see on mine tonight.
