Not charging at 45 Watt on my Galaxy S20 Ultra.
Works for few minutes then charge at normal speed.
Anyone else experiencing this?
So below 40 it is super fast charging? You have the Exynos version?1% when I put it on charge, then slows down about 40% battery
No the one that comes with the phone is a 25 watt charger... 45 watt charger i bought separately... And only the Ultra supports 45 watt charging.Does the S20 come with a 45 watt charger.
Or did you go out and buy one.
I thought the 45 wayt charger was a accessory.
Why go with the ultra? Get her a S20 or S20+I didnt think any of them came with it.
And , Oh !
Thanks for letting me know. Only the untra can use it.
I wanted to buy my wife a new phone in a few months If I like how things are going .
Not sure after her using a note 9 with the finger print sensor on back, if she would change..she would never buy a new phone.
And with the ultra being so big,it would probably be a problem for her to carry it and more weight.
Thanks
They too come with a 25 watt charger and should charge relatively quick. And would fit your wife's hands. Question is would she be happy with the in screen fingerprint sensor ?
Exynos is for certain markets outside of the U.S.how do you get a non Exynos version on a unlocked phone.
But it direct from Samsung.
You don't have a Exynos processer. You have a U.S. versionI run about phone on my note 10+
It says it was made in Vietnam by mutant.
Don't say nothing about a exynos chip or anything.
My notr 10+ hotspot is great.
It works well with the Snapdragon. Seems the Exynos has a lot of issues. Perhaps an update will fix it.Yes, I have Exynos version.
I recommend people not to buy 45Watt charger it's waste of money. I can't even charge at full speed.
Why is Samsung still selling this piece of crap. Can't even take full advantage of my S20 Ultra.
The new update slowed it down reported by Sam Mobile web site.
Yes....to bothDo you have Samsung Galaxy S20 Ultra?
Also do you have 45Watt charger?
