On iOS there is a screen that tells you if your battery is performing at peak performance or not. Does Samsung/Android have something like this? Thanks in advance ac!
Not by default no. But you can download an app called AccuBattery. If you download it, tap battery health and it will give you the information you need. Charge your battery first and then install it. Then use it as you normally would. Then check back with AccuBattery to see where your battery health is standing.
