The top speaker seems to be offset to the left, so that sound comes from the centre and left side (as you look at the screen), but not really from the right (maybe because the noise cancelling microphones are on the right?).
This means the phone works better in your right hand with your right ear for calls.
I'm wondering if this is a quirk of my phone or a design choice on all of them...
