Might have to reboot the phone also, next will be settings>apps>3 dots upper right corner tap>reset app preferenceNope, still doing it with NETFLIX.
and Video as well..
and Video as well..
Ok keep me postedJust installed new update for my android and rebooted.
Surprise, the Netflix videos no longer go back to main netflix page, but still stops the video and blinks like some command is been sent.
I'm going to record this behavior again and see whats going on.
Ok keep me posted
In a completely turn of events.
The error happened once In Netflix then it stopped happening. I sat thru 2 episodes in Netflix and no return to main screen. Tried the camera too and nothing.
I'm going to reboot the device again and see if the issue is resolved for good.
Good to hear hopefully resetting settings or app preference did it
It was actually either the combination of the settings and app reset AND the patch update, or the patch alone.
Because there was no effect ( still getting the bugs a) with the resets alone.
Thank you both for the help!
If your satisfied with the way it is thats great otherwise factory reset and dont bring over back up. Install them little at a time
