Volume settings auto-adjust themselves?
ciera richez
4
I've had this phone for a few weeks now, and so far I love it. But I'm having an issue with my volume settings...they seem to adjust themselves. I have them set where I want them, and without touching the phone they adjust themselves to where they're hardly audible. I have the Deep Sleep Battery Saver app on my phone, but I've already checked the settings within it, and I see nothing about automatic volume changes if my battery level gets down below 30%. I do have Power Saving mode enabled, so I'm wondering if that could be the issue...but if that's what's causing the volume changes, how do I stop it from doing it? I've noticed that, even after charging the phone, my volume settings don't go back to where I originally had them set before Power Saving mode comes into effect. If someone tries to call me when the volume is down without me knowing, I never hear the phone ringing.
Is there any way to fix this problem? Thanks in advance.
Has this happened from the time that you took it out of the box, or did it start after you started installing apps?
Do you have a case on the phone that might be inadvertently pressing the Volume Down rocker? (I assume that the volume never increases on its own?)
You could try booting into Safe mode and see if the problem persists. (IIRC, with the phone completely off, press and hold the Volume Down rocker, press the Power button and continue holding the Volume Down rocker until the phone has finished booting. You'll see 'Safe mode' in the lower left corner.)
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
It's done it since I got it out of the box. I've determined it's from when the Power Saving feature on the phone is enabled. As soon as it hits 30% battery and that activates, it changes all my volume settings. So...is there any way to configure the Power Saving feature on the phone so it doesn't do that? Because I haven't been able to find anything when I've looked.
That's very interesting (and something I would never have thought of). It makes sense that while in Power Saving mode it would decrease the volume levels to save on battery life; unfortunately there's nothing in the Power Saving help information to indicate that it modifies the volume levels.
Once the volume levels have been modified, what happens if you reset them to the level that you prefer? Do they stay that way or automatically get reset to the lower level?
You may have to choose between Power Saving mode (which I don't happen to use) or having to fiddle with your volume. :banghead:
The settings seem to stay if I adjust them after Power Saving mode is enabled...I just wish I didn't have to try remembering to do that, because a lot of times I forget. LOL Is Power Saving Mode really necessary, though? I also have the Deep Sleep Battery Saver app on my phone, so maybe I don't need both?
As I noted, I haven't found Power Saving mode to be useful, nor have I relied on other power management apps. I get what I consider to be adequate battery life, and choose to manage screen brightness as necessary; to switch between mobile data and Wi-Fi as necessary; and to charge whenever the opportunity arises. YMMV.
I've decided to stop using Power Saving Mode myself. That should at least solve my volume issue. I have to say I do wish my battery life was a little better than it is, but I guess I can't really complain about that...after all, it is a smart phone. Thanks for all the help, it's much appreciated! :-)
I too had this problem..it is really annoying...
It is due to AVG antivirus..see if u have installed it...u can change this setting in AVG under performance menu...
Oh my god this has been driving me bat **** crazy lol Thank you for the advice regarding AVG that was def. the problem!
I do too have the same problem the volume keeps self adjusting to the lowest level. I also noticed it seems to happen when the headset is used while running or exercising in the gym.
Yes due sum apps after stallation I get this issue I uninstall all that apps main was jio apps controlling my android os
I fixed it by removing the tiny circuit board inside the talkback mic on my ear buds. This did remove the talk back mic but I never use that anyway. Then I filled the entire cavity with hot glues before replacing the tiny outter plate so no moisture could leak in and trip the circuit.
mhuk01
