Red Light is on
crisg723
76
8
What does it mean of the red light near the front camera is on? Had my GS3 for almost a month and this is the first time I think I seen it.
That's the sensor for motion stuff like direct call and smart stay, it sounds only be on when a motion could be used,I only have direct call so mine is only on during texting threads
Sent from my SCH-I535 using Android Central Forums
Mine is red when I have a Facebook notification...I don't believe I changed any settings.
I've seen it too. When I'm in my bedroom and it's dark I can see it too.
And just so where all on the same page, I'm referring to tone of the 2 small lights that are by the front camera, not the notification LED by now the other side.
Ah, yea those are proximity and light sensors... Don't know why they'd be lighting up...
Sent from my ICS loaded Samsung G S II E4GT
I restarted my phone and it went away. Don't know why it was on in the first place myself.
i found a solution ;))
After i tried sooo many app to disable this sensor light. I found that the solution is to open viber and exit from it ( from settings select exit don:t exit by home button) and try
Proximity sensor
On my Samsung galaxy s3 running android 4.0
Because unlike ios, i keep my apps in app drawers, and not in infinite cluttered homescreens
Wow i?m impressed Rizsye that you found the problem I thought something was wrong with my phone but i followed your instructions and it fixed it. Great work.
noticed lastnght that my prox sensor glows and im guessing its the Wave Control app doing it but the app only uses 2% battery in background so i dont care :)
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
i dont have viber
You are grate dude it's the real answer for that.i thought my s 3 was broken now Im REALLY REALLY HAPPY MANY MANY THANKS
fistyjone
