Yeah I am guessing it was the constant texting, which also uses some phone power as well. 9 hrs and only 66% is not that bad anywaysI have the screen set to shut off after 15 seconds. Brightness is set to 20 percent.
I did text a lot today. But this just seems like a lot.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Your texts are also being processed by the stock SMS app in the background, as well as Go SMS Pro, so each text is using an unnecessary extra amount of power. Probably not much, but some. If you are a heavy-duty texter, it could make a difference.
FWIW, I also used Go SMS Pro for a while and decided I didn't like it ? it was quite intrusive, screwed with the notification settings, and the font was too small. I uninstalled it and now use the stock app, which works fine for me. YMMV.
Yeah I have this one but I don't like the bulk that it adds to my phone.
Thanks for replying.
