GSDer
Welcome to the forums!
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
That sounds like a typical symptom of a stuck Power button/switch. You should pursue that fix until the phone no longer turns itself on when you insert the battery; then come back and we'll look at any booting issue.PS: Could the thing with the stuck power button be an issue? After putting the battery back the white screen appears automatically without pressing any button
