[Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
This is your guide as to how to reboot into Recovery. I have noticed many users do not know how to do this, so I figured I would write a step by step guide with photos on how to do it.
I will be using my Tab 2 as a demonstration unit, and for screen shots as visual aids.
[TIP]Rebooting into recovery or even knowing how to use it can be very helpful. Being stuck in a boot loop, apps crashing, or just a general clearing of problems can be fixed using this method.[/TIP]
Step 1: Power down the device. Pulling the battery will work as well, especially if you are caught in a boot loop.
Step 2: Allow the device to completely shut down. Waiting until your screen is off, or just giving it a full minute or two should suffice.
Step 3a: For the Galaxy S2 and Tab 2, you will need to hold Volume Up and Power at the same time until you see the Samsung logo appear. Then release.
  3b: For the Galaxy S3, you will need to hold the volume up, home, and power button at the same time until you see the Samsung logo, and then release.
Step 4: For all variants mentioned, you should now be looking at a menu list with a blue highlighted bar. Using the volume rockers will navigate through the menus, and generally power is your accept button. The S2 might have a little twist. Upon getting into recovery, you can push up, down, up to enable the back button. This also allows to use the power button as the accept button. See figure 1.
Important note: When navigating around in recovery and you select something, you may be redirected to a page with about a dozen answers. Almost all will be no with yes buried in the middle. This is to prevent accidental accepting of an option.
4b: To actually have you use this guide, you can clear your phone's cache. See figure 2. There are many cache clearing programs on Play, and while they may clear the cache as well as rebooting into recovery, this is merely an alternate method. Click power to accept.
Step 5: When completed, you can navigate back, or usually after completing any action in Recovery, Reboot Now will be highlighted at the root menu. See figure 3. This is your gate back to running Android through the User Interface. Click power to accept.
Congratulations! You have successfully entered, navigated, executed a command and rebooted all in Recovery. This is also a method to flash a ROM through a .zip file on an SD card, and a complete Factory Reset can be accomplished in this manner as well.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Inquiring minds want to know.....so I have thus informed them...:D
The above Guide has been tested, and confirmed to work on the Sprint Galaxy S4
Thanks to user Travis Gubernick, this has also been tested and confirmed to work on the Verizon Galaxy Note 2.
Paul627g
AC Moderator All-Star
Moderator
Nov 25, 2010
15,963
2,752
Looks good. Actually as silly as that sounds there are many that don't know initially how to boot into recovery and the big part, what it looks like when they get there...
sastrysrikanth
I have been trying to reboot my samsung galaxy grand duos GT 19082 using this procedure (the phone actually shutdown and came back with this prompt) but the reboot system now command does not work. After showing the model number on the screen and a wait, the phone comes back to the reboot menu. What is the next step?
FishenFool
317
I just had to do this because I had a boot freeze. I unfrozen it by connecting to a computer but most of my apps didn't work right or were no longer installed and trying to reinstall resulted in an unknown error during the installing phase. Really hate the fact that I lost all SMS and call logs so I have installed an SMS and call log backup. Also totally hate the fact that my latest Nova layout wasn't backed up (my fault) so I am having to spend time getting everything back the way I like it.
Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
I'm not sure about that model. As the first post says, this procedure is known to work on the S2 and S3. What other options appear in the recovery menu? If nothing else works, you might try a battery pull while on the recovery menu.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
I would suggest to find a stock recovery download and flash that to your device. It may be possible something is wrong on the OS.
jd0520
What app did you use for your SMS and call log backup?
GSDer
8,471
15
You can use these:
Helium: http://market.android.com/details?id=com.koushikdutta.backup (does SMS but not MMS; unsure about Call Logs)
MyBackup Pro: http://market.android.com/details?id=com.rerware.android.MyBackupPro (there's a trial version; does SMS & MMS and Call Logs, but the MMS restore is iffy)
SMS Backup and Restore: https://forums.androidcentral.com/e...om.riteshsahu.SMSBackupRestore&token=Wq7oVHib (doesn't do MMS)
Call Logs Backup and Restore: https://forums.androidcentral.com/e...iteshsahu.CallLogBackupRestore&token=VKCSB11I (don't ask me why he split this functionality into a separate app)
But I'd recommend using the Kies software on your PC - it does Contacts, pictures/videos, SMS/MMS, Call Logs, system settings, etc. You'll be hard pressed to find something that does MMS, and Kies is easy to use once you get the drivers set up. On top of that, you can use it to reload the firmware on your phone should the need arise.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 2
jennapi
8
I tried doing this because it felt like my battery was draining much quicker than before after an update (that was the advice given here, and it seemed like it might be applicable). It said "Erasing" before coming up with an "Error" message and then rebooting into normal use mode. It still feels like the battery is draining faster than normal. Do you know of something that could be wrong?
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
If I had to guess, it may be an error in the recovery. If you are up for it, you can try flashing the stock recovery.
Sent from a Slim 4.3 S3
GSDer
8,471
15
jennapi,
You should try booting into Recovery mode again and clearing the cache. If you still get an error then I'd suggest performing a Factory Reset, particularly if you haven't done one since receiving an OTA update.
Be sure to back up any important information - you can use the Kies software on your PC to backup your contacts, SMS/MMS, call logs, pictures/videos, etc.
If you want to backup your apps and app data you can try the Google solution (in Settings -> Back up and reset, check the box that says "Back up my data" ) or you can try a proven solution like Helium: http://market.android.com/details?id=com.koushikdutta.backup
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
IYIBIZ
9/28/13 Galaxy Tab2 10.1 updated it’s operating system I’m guessing to 4.2? It looked different, now won’t connect to internet, seems stuck in a boot loop.
I read about these problems on this forum and tried to go through the steps to reboot into Recovery to clear the cache. I held the power button and up volume button til the Samsung logo appeared and released.
And...opps! I must have done something wrong because I came to a screen that I ‘think’ said warning if I wanted to install/change the OS, push down volume to continue, up button to cancel....well I pushed down button thinking I would get to the recovery mode and now my tab is stuck with a screen that reads in red ODIN MODE, white PRODUCT NAME:GT-P5113, CUSTOM BINARY: NO, CURRANT BINARY: SAMSUNG_OFFICIAL. In the center of the screen is a large android symbol below it says: Downloading... Do not turn off target!!!
Please where do I go from here?
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
9/28/13 Galaxy Tab2 10.1 updated it?s operating system I?m guessing to 4.2? It looked different, now won?t connect to internet, seems stuck in a boot loop.
And...opps! I must have done something wrong because I came to a screen that I ?think? said warning if I wanted to install/change the OS, push down volume to continue, up button to cancel....well I pushed down button thinking I would get to the recovery mode and now my tab is stuck with a screen that reads in red ODIN MODE, white PRODUCT NAME:GT-P5113, CUSTOM BINARY: NO, CURRANT BINARY: SAMSUNG_OFFICIAL. In the center of the screen is a large android symbol below it says: Downloading... Do not turn off target!!!
Press and hold the power button. You accidentally went into download mode.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Press volume up to go into recovery.
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums, by the way...
GSDer
8,471
15
If it's anything like the S3 you'll have to remove the battery to get it out of Download mode.
Racheinderbys
Hi, I can't seem to get this to work. My phone is a Samsung Galaxy S2 and the battery suddenly started draining very fast. Finally it closed down and now it won't reboot, even when charging, getting stuck at the "Samsung" logo. I am trying to follow these instructions, but I have a couple of questions:
a) is the "power button" the one on the RHS of the phone? Just checking because It does other things than simply turn on/off power.
b) on which version of the Samsung logo should I stop holding the buttons down? The reboot cycle goes "Samsung Galaxy SII GT-9100", then a sort of explosion, then "Orange", then (much more quickly than normal) just "SAMSUNG". This latter is where it stops now. Should I release the buttons the first time I see "Samsung" or the second? I have tried both to no avail, but want to keep trying as it is 2 months before my contract runs out and I can get a new phone...
Thanks in advance for any help.
Rachel
Golfdriver97
Moderator
Dec 4, 2012
35,367
113
63
Rachel
Stop at the first Samsung logo. Follow directions above, and stop there.
From a Sprint Moto X using AC forums app
AmeliaRodriguez
