S4 or s4 mini need help!!
nimdass
13
Hi guys,
I was planing to buy a S4 I9500 but the 5" screen really seems too big to hold. I think you got used to it after some time but the S4 mini seems more comfortable for me.
When you look at the specifications you see that all the garish (I dont think that I used the right word) options that S4 I9500 has are GONE.
The 13MP camera, sensors, internal memory, processor, gorilla glass screen and etc.
Does it worth to buy a S4 mini or staying with the big dude is better? And is the S4 mini quick?
Thx
It could depend on how important something like the camera is. I recently got the s4. Take a lot of photos for work and love the camera on it. I think I would prefer a slightly smaller screen ideally... But with the same camera. So in the end, the s4 was the better choice overall for me though. If the mini was the exact same phone only smaller, I would have likely gone with it. But it's not.
First, your avatar is interesting. Second: if you are in the US, just try one for 14 days then the other.
modsmelon
