WatchON SKY+HD Problem
Neilbull
Hi all,
I have a Samsung Galaxy S4, and would like someone to let me know if the Samsung WatchON app is compatible with Sky+ HD in the UK, as the nearest I can find on the app is Sky+ and it does'nt work properly.
Thanks
Neil
steve short
Active member
Jan 26, 2014
25
To select the HD channel launch the WatchOn app. Select the pop out menu on the top left corner.Select channel guide and find the HD channel amd program you want from the list.(I'm a UK user)
Sent from my SM-N9005 using Tapatalk
steve short
Active member
Jan 26, 2014
25
Have you tried all the different regions for sky when setting up? I remember when I set mine up initially it didn't work using the settings for sky in my area I had to use settings from a different area(meridian) to get it to work. I've also noticed when ever the app updates the settings get messed up. Sorry I can't be any more help. It's a pity there's no proper set up tutorial from Samsung as it's a great app that's understandable used.
drkrleitch
