CLivesCrazyLarge
Hey all,
I had done a basic glass repair on the i337 t-mobile Galaxy S4. After cleaning off the glue with some alcohol gently and re-assembling the board back on etc, to make sure the screen was good to go after the repair. When this was all done and it was time to turn it on, it began to flicker and change colors. I tried the auto brightness and unchecked auto tone in settings>display it seemed to have worked for a short period then went back to the same shenanigans. (yes i just said Shenanigans ) I had left it for a little while while doing some research and then came back to it to find it now won't even turn on. When I start the phone up only the LED will light up for a short period of time after the phone vibrates and then will give me one short vibration without the screen starting up and it will repetitively do this without ever turning on.
If anyone has experienced this it would be a great help to hear your thoughts.
