I have problem with usb connection.
edib
4
Hello androidcentral members.
I have Galaxy S4 device and i have one mistice problem. When i connect Usb cable to the PC my device charged OK but Usb connection not work, but when i go to download mode ODIN connection worked good. I reinstall 3 times OS , 1 time official OS and to times Rom OS but problem not solved.I trie to reinstall drivers to PC but not work. When i connect AC Adapter on electricyti devide charged ok but on display not notify anything.
Thanks and Respect.
Peterzahn
14
Do you have the option to use another USB cable? Heared about it, that the USB cable can disturb the data connection. Try it with another cable.. maybe it helps
smokedog87
