HI everyone, I have had sever battery drain lately but i'm not sure if its a rogue app or my phone that is the problem. But not sure if factory resetting it will be the answer. Sorry for teh massive clump of info i'm just a little worried.
2 days ago i realized my phone was at around 17% after charging it 3 hours earlier to around 75%.
The day after I charged my phone to 100% and with in 2ish hours my phone died
as you can see its says I have had WiFi on the whole time but if you look at the notification bar WiFi is not on at all
I had a similar problem later in the day when i tried charging it again but this time, used Gsam app to monitor it and had similar results
This has the same problem but I don't see what could be casing the Issue. However Once it lost battery I gave up and left the phone only to find this morning it doesn't even charge anymore. So I went out to the store this morning to buy a new Samsung official battery. but unfortunately have had similar results. This means it must be an app or the phone.
This is of the new battery PS I had the screen on dimmest setting, OK google and location turned off, and data off. Wifi was only on for a moment. and was on power saving mode
You may see the small drop at the end of the blue graph. I went for a run for about 40ish mins and came back and it had the same percentage as when i left but after 5 secs of turning it on it lost a few percent, this seems to happen often as i have been monitoring every now and then.
I tried updating all apps that's why google play usage is so high. Sorry for the info overload possibly someone knows a solution
Thanks Connort226
Thanks Connort226
