I had to sign up to post this because im now having battery issues after some 35-40mb OS update came through the other day. Im with Telstra (Australia's biggest network with best coverage I have good 4G coverage at home and work as well)
I used to get through a day 8:45am off charge, go to work, wifi connection all day, bluetooth connection all day to my Samsung Gear 2 watch, bluetooth to car 40 minutes in the day, go to the gym and then bluetooth audio to my plantronic backbeat go 2 earphones for about 90 minutes (while using gear 2 via bluetooth to control audio) and get home with about 75% battery remaining. On a bad day, maybe 65% remaining. Location services turned on, gps turned on (use it with friends for google locationing each other) then put it on charge at about midnight where i still easily had over 50% battery remaining.
Since this small update that came through, I now use close to 10% battery an hour... doing nothing... Its just stuffed and im not going to turn anything off because i need everything on....
Lucky for me I am in a position where i can keep it charging but still its a joke. I just want my old battery life back....
It also seems my screen seems to be using up a fair amount of the battery life (31.5% so far today) and my screen hasnt even been on that long with it sitting on my desk.
Im going to try a few things, might even factory reset to see if it improves anything.
Just wanted to add my 2cents
Cheers,
Jaydee
