Problem with using another lock-screen app on the Galaxy S5
Hello everyone,
I've been having a problem where whenever I turn on my screen (by pushing the power button while the screen is off), it displays the current contents* on my phone for a split-second before it heads over to the lock screen. The lock screens I've tried out are CM Locker and Echo Notification Lockscreen, which were chosen because of their good ratings.
One thing I've noticed is that this only happens whenever I turn on my screen by using the power button, and not when I turn on the screen by using the home button.
What could be a possible solution to this problem?
*More specifically, it shows the screen that was displayed right before the screen was locked. For example, if it showed google chrome, it would also show that for a split-second. If the screen was not unlocked, and you simply pressed the power button without unlocking the contents of the phone, it just shows the lockscreen right away (since the lockscreen was technically the last thing that was shown before locking), so that's not a problem.
Hello everyone,
