How can I see my emails in my car from my S6 EDGE?
A
AC Question
S6 EDGE car connection
I have connected S6 EDGE to my car (Lexus) and phone and texting is working fine. I do not see my e-mails on the screen. I had BB Z10 before, could see e-mails from all accounts as well. Is EDGE not sharing the e-mails? Is there some setting I can change?
Thank you
JHAM808
Re: S6 EDGE car connection
Depends on car I think. I have a bmw and it works fine after setting up Bluetooth
stefan kjellberg
I have done Like this after a lot of trubble, but it is now working.
First I followed, with no luck all the advices but a Factory reset, then:
1 Factory reset
2 Start Quick Connect, goto settings for this an select the most sequre settings ( I expect that the reason for the problem is a bit Similar as the old 1990 limit in KitKat)
3 Goto your car and and pair as normal.
4 I do not use the BMW conneted drive sine i disables bluethooth.
After this i get:
All Contacts
All email
All SMS
All Call History
HUD display of playing song, and stearing Wheel nav of song..
Correct song title when I steram Spotify.
I ahve atteched images below, hope they display..
RK_BB
Trusted Member
Sep 7, 2015
13
In order to see emails in your car infotainment system you need to have your email account configured on the stock email app. No 3rd party email app will work.
The problem with Samsung is that it only syncs the default email account whereas other devices sync all configured email accounts.
Non
