Auto brightness battery sucking ?
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Depends on where you use your phone. If you're in direct sunlight or other bright light sources, it will definitely use more than having it set to low manually. If you are indoors or in the dark a lot, it will probably be better than what you set it to. I have my phone on Auto (not an S6) and I still get great battery. Could get more if I set it to the lowest possible, but that makes it less than ideal in most situations and having to adjust every time I change scenery isn't worth the extra bit of battery
tivativa
