So I have S4 currently and can upgrade through ATT. I was looking at the S6, but the only thing holding me back is the battery and the knocks Ive been hearing against it (I was against the non SD card issue, but I think I'll be fine in the end, all my music, all 12.3 GBs of it, is on my SD card in my S4). What I'm wondering is with my usage is if I'll be fine. I charge it overnight (with phone off) and when I get to work (with my current S4) I'm at around 96%. I rarely mess around with my phone while at work cause I'm constantly moving. At lunch I'm usually on it for about 20-30 minutes (depending on if theres anyone to talk with). As it is now when I get home I have anywhere from 40-70% of my battery left. If its too low I'll charge it when I get home. For the most part I'm a Facebook, Web surfer, and minor game user (Words with Friends, Trivia Crack, Dice with Buddies, etc). I use my phone I feel more for music (both at work, and through Bluetooth in my car, and use the Power Amp music app). I have my WIFI on all the time since work has free WIFI. I wouldn't consider myself a heavy user. So with that said, and the fact I'm going to disable a bunch of stuff when/if I get it, along with using power saver mode, do any of you think I'll have battery issues or high battery usage? This is the only thing I'm worried about.
The only other question I have in regards to storage, is how much does the phone use in storage (stuff like bloatware, OS, etc). I know most true storage is never the amount they state cause the OS and other crap takes up some of that space. I figure with the music I have minus the 32 GBS, it would be around 20GBs left, and less with what the phone takes up. I don't think I'll need the 64GB, but I want to make sure.
Honestly I'm torn between upgrading to an S5 or an S6. I've heard theres not much of an upgrade between the S4 and S5, but then the S5 still has a removable battery and a SD slot. I feel though there would be a greater jump in upgrade between the S4 and S6.
