I was thinking before I disconnect and get ready to sleep about the people that even when have done most of the tweaks and have wiped cache and Factory reset it and still have some drain issues, something must be in common every time with every reset, a rogue app or what has been the cause of issues before, widgets.
So If you have tried everything, then you can try something else, are you using the default weather widget? If so, just look for anything that begins with weather in the applications manager and clear cache and data of that app, then remove the widget.
I don't have it, I disabled it and removed the widget as soon as I got the phone as I just use another weather app, but if Samsung is still using the same old Accuweather app behind it, man that app can be buggy as hell and it won't be the first time it causes drain issues.
Again, just trying some different approach as at this point you won't lose anything trying new stuff. Let us know if you do it and if by any chance it works.
