PsychDoc
yay!!!!!the device is not 5.7 in it is 5.5in
posted via the android central app
I'm getting it then.
Thanks for the update
Neither of the S7 have usb c even tho it is a convenient. No single manufacturer actually takes advantage of the data to transfer speeds or the charging type c is known for. Plus makes it easier for gear Vr use.
The device is not 5.7 in it is 5.5in
Multi color led yes and IR no. Most tvs have smart apps now or apps for cable providers or game consoles.
No usb c is unfortunate. It's so easy. My kid broke my s6 edge plus trying to charge it. Wouldn't of happened with usb c. Is the battery removable?
Had about a hour with the phone today. Have full breakdown about all of the aspects of the phone.
Any questions?
How did you get access to it?
5.5?
I'm out. :'(
What were you hoping for, 5.7"?
If you want that, get the Note. For me that's just too big. 5.5" was what I was waiting for for a while. I'm super psyched.
If you had the black version is it actually black? Or that dark blue black color?
I'm confused. The regular S7 will have 5.5 screen? What will the "Plus" size S7 have?
I don't think I can use anything under 5.5, so 5.5 is fine with me. (my previous phones are Note 2, 3,4 and current phones are Note 5 and LG G4)
Were you able to check the Force touch capability of screen?
