Couple of people have asked for my settings.
The key ones are :
Nova:
Desktop grid 12 x 9
No width or height padding on desktop.
Snap to subgrid checked.
Width and height padding for dock set to large (this brings the icons on from the edge a little more than shown in screenshot).
7 icons in dock.
Icons on desktop and dock set to tiniest.
1 dock page
Transparent notification bar with dark icons (not shown in my screenshot).
Icons manually set in dock and row above, packs used Nox and 3KSr black (move icons for apps you want in dock etc to homescreen and long press to edit, labels deleted)
No icon theme applied anywhere else.
Circle launcher:
(add the CL short cut to desktop from your widgets menu once installed, change the icon as described above once all set up)
Circle style, set to about 180% size
Apps in circle
Circle centred
Icons in circle set to size as liked
.... I've also used Nova to set gestures (double tap to sleep with Screen off and Lock, drag up to show calendar, two finger swipe up for contacts etc).
HTH.
Play, have fun see what you like!
