Post homescreen screenshots taken on your Samsung S7 Edge!
...and with circle launcher open (I want to play with the size of the circle to bring it in a little).
I use the edge handle only for weather and calendar items...at the moment.
So I'm fairly a newbie, but how are you using nova and circle launcher?
Nevermind! Figured it out. Ha. Nice setup though
Ooh... Questions... In reply...
I don't apply an icon pack to nova I manually set the icons for each item (long press icon >edit>select icon from whatever pack I fancy).
Circle Launcher... I place the CL shortcut (one of the CL options under widgets) on my home screen, set it up then change the icon (in this case I'm u sing the one that looks like a button of two circles inside each other on the far right of... I'm not sure what it's really meant to be the Icon for). HTH
So you just go to the app store and download circle or nova launchers and is it for rooted people? I know I've had all HTC phones but still I have never had another launcher always used HTC and Sense never rooted. So if I do just download from app store how do you go back which I may not want too LOL!
No I'm not rooted either. You can download nova, circle launcher and icon packs from the play store..... Dead easy to go back just reset your launcher to use Touch wiz.... Settings >Home (.... Or summat like that). Nova has a wee bit of a learning but you just play and fiddle til you have the set up that suits you.
My screens:
Nova Prime.
Haven't messed around much other than using themes, really excited seeing what this phone is capable of
Here's my S7 edge. I'm using z launcher, it's clean and constantly adapting depending on most used apps and location I use them, I used it on my s5 as well and still love it.
Couple of people have asked for my settings.
The key ones are :
Nova:
Desktop grid 12 x 9
No width or height padding on desktop.
Snap to subgrid checked.
Width and height padding for dock set to large (this brings the icons on from the edge a little more than shown in screenshot).
7 icons in dock.
Icons on desktop and dock set to tiniest.
1 dock page
Transparent notification bar with dark icons (not shown in my screenshot).
Icons manually set in dock and row above, packs used Nox and 3KSr black (move icons for apps you want in dock etc to homescreen and long press to edit, labels deleted)
No icon theme applied anywhere else.
Circle launcher:
(add the CL short cut to desktop from your widgets menu once installed, change the icon as described above once all set up)
Circle style, set to about 180% size
Apps in circle
Circle centred
Icons in circle set to size as liked
.... I've also used Nova to set gestures (double tap to sleep with Screen off and Lock, drag up to show calendar, two finger swipe up for contacts etc).
HTH.
Play, have fun see what you like!
RangelS25
