RichBrown68
Banned
Okay now in that click battery usage.The settings under battery totally confuse me. LOL. But this is what it reports right now
Yes. Basically check it around 15% without charging it in between. Then upload screen on time picsJust had a thought that might clarify it. When it says come on, are people checking this when their phone is close to 0 and then this tells them how long their screen was able to be on before reaching that point? Because I just started using my phone off of fresh charge.
Is this normal ?
Hardly used my phone as I been sick past two days.
View attachment 223193View attachment 223194View attachment 223195View attachment 223196
The best would be to charge your phone when it says so. Comes up with a notification to charge at a 15% .Gotcha. Will do. this will test my OCD about never letting my phone get below 50%, but I'm up to the challenge. LOL
Has anyone experienced more than usual battery drain with Bluetooth? I've had Bluetooth on for all my previous devices as well since I use it with my car and fitness band, and on S7 edge Bluetooth share is showing in the top3 most battery draining apps on Gsam. It is draining 6-7% each cycle.
Interesting part is that it shows Bluetooth itself draining only 1% on gsam but the app Bluetooth share is the one draining the battery. Is this a Samsung thing?
I am using T-Mobile version with SD820 if that matters.
I get pretty good battery life on mine. I'm on tmobile as well getting 5 to 6 hours of screen time. I usually have my gear s2 and headphones connected and the Bluetooth is always at 7 or 8% of my battery. I'm coming from an iPhone but I don't remember this being as high on previous android phones.
I've never ever once seen bluetooth show up on my battery stats and I keep it on 24hrs a day as it's connected to my Gear S watch.
That's damn good I only get 1 hour at about 10% down from a full chargeI swear some days the battery life of this phone is beyond anything imaginable. Granted I was on WiFi and just reading the forums but this is a pretty common pattern for me as I like to read on the device due to its screen size.
//uploads.tapatalk-cdn.com/20160403/e26e53a1243af0cf4e03926dc4eba54c.jpg
It's hard to see what the BT percentage is n your screen cap, but it shouldn't be that high. As I said above, my phone is connected to a Gear S watch all day everyday and I never see BT on the battery stats.It's still good battery life but the Bluetooth is strange.
I have a second S7 Edge that actually is getting less battery usage then the S7 Edge connected to the Gear S. That second phone has BT turned off and when I got the second phone, I used Smart switch to copy everything from the first S7 Edge so they were identical in every way, just different sim cards.
