AS7Edge
Hello new here, I just picked up a galaxy edge 7 from t-mobile and I'm loving the phone and battery life
I normally have 5.5 hours SOT. I've installed package Disabler pro + last night and gave it a try. So far, so good.
//uploads.tapatalk-cdn.com/20160514/d8bcc8a719c3ca53d4440be779fdbe07.jpg
//uploads.tapatalk-cdn.com/20160514/bc32c3673d9b32e8f7b6d3bb02a0963a.jpg
I think mine might be sorted. Took it off charge and have streamed pocketcasts to the car and been on 4G with a couple of calls for the past 2 hours and I'm at 94%. Over the past while this would have been 80% at best.
What did you change to sort this out?
Back when I had a s6, I read somewhere that if you use any sort of backup program to back up ur phone and then transfer it to your phone, supposedly the battery life is worse. Since then I've always started fresh and had no issues.
This might sound strange but I really think it was smart switch that caused my issue. I had been blaming the APD3 update, but when I got that update I factory reset and did a smart switch from my Oneplus One. Since that I'd been having problems with something running in the background that I couldn't pinpoint, and a few services that didn't look like they belonged (though I'm not 100% sure on those but after a lot of Googling apps like OM Customise didn't seem to be a Samsung thing).
Anyway, then I remembered a PocketCasts issue that I'd been having when streaming to my car on the Oneplus that I'd never had before on a phone (was only using the One a week, PocketCasts would not pause audio for a call and would randomly stop and jump back a few minutes when restarted). I'd started having these exact problems on the S7 too so I was suspecting something carried over that shouldn't.
In the end I factory reset and used no backups at all but started completely fresh. The battery issue and podcast Bluetooth issue have both gone away (have 76% remaining with 8m keep awake so far, before my keep awake over 7 hours off charge would have been at least 6h30m). Maybe the issues will come back but it looks good so far.
One of the reasons why I don't want to do a factory reset and start new is because I like that I was able to transfer my text messages over to my new phone. I wasn't able to do that when I switched from iPhone to the S5 2 years ago, so it feels comforting knowing that I was able to keep the text messages. That's very important to me. I have my pictures on my SD card, which is fine, and the apps I can always re-download myself, but if I were to lose my text messages, I would be disappointed. That's one of the things I didn't like about switching from iPhone to Android - I wasn't able to transfer my text messages over to the new device so I am thrilled that Samsung made a solution for that. I just hope that whatever is draining my battery will fix itself with the next update.
One thing I always do after any sort of major update is unistall and then reinstall any large apps including third party launchers, and then disable and enable all Samsung and Google Apps. Works like a charm for me everytime.
I'm not a huge fan of Smart Switch. In my case both a restore from my LG G4 when I first got the S7E, and then a restore that came from the S7E after I did a FDR a month or so in, left a lot to be desired. I didn't find I had any rogue apps as a result. My complaint was more that Smart Switch didn't restore anywhere near enough data. I still had to take quite a bit of time to get things as they were. Note that I had used LG Backup a number of times and it did a far superior job in putting things back as they'd been. So, I do have something with which to compare Smart Switch.
That said, I did have the rogue app issue with LG Backup when I used it for restore. When I first got my LG G4 I restored a backup and wound up with the Fenix app for Twitter running rogue, giving me very high Keep Awake times. The problem was that it wasn't evident from Fenix's own battery stats. The Keep Awake time showed up in Android OS. It came down to a week or so of trial and error to pinpoint Fenix. I don't think Fenix is a problem itself, but the way it was restored caused an issue. I figure that's also a possibility with Smart Switch.
