Vinman911
Same here. Searched it and downloaded both browser and adblock plus. Works on my Verizon S7 edge.
I'm still getting "Your device isn't compatible with this version." Verizon S7 Edge as well.
Nope same old same old... I even rebooted to see if that would clear it up. Oh well I am happy with Chrome for now. I guess I have to be. haha
Same here. You all have me interested enough to want to try it.
Tried AdBlock browser and compared it to Dolphin. Dolphin was clearly faster and smoother. Uninstalled immediately.
i did the VZW update today, then searched the Play store and do not see the browser
Just a little bookmark workaround. Create a separate folder and put all your bookmarks in it. It will always open to that folder once you are in it. Even if you close out the app. That way you can have all your own bookmarks without the annoying ones we cannot delete.I was able to get this and iI have to say I'm blown away. Really like this browser, I've been using Dolphin for the ad block but this is way more polished. Some goofy inconsistencies (can't delete default bookmarks? C'mon) but this will be my daily driver.
I had to search Google for it to find it in the play store, a search through the app did not bring it up. Once I opened it on the play store I could install. I have not done today's Verizon update BTW, so only have the first one installed.
