When I'm playing music I have to unlock the screen to perform forward, etc. Is there a way to display media controls on the Samsung S7 lock screen?
P.
P.
I had this problem also - you have to turn on notifications for the app, and then *also* turn on notifications for that app for the lock screen.
Step 1 - Settings --> Notifications --> Turn on notifications for GPM (or other)
Step 2 - Settings --> Lock screen & Security --> Notifications on lock screen --> turn on notifications for GPM.
All done
Edit: The above is actually for a regular S7, not the Edge, but my guess would be it's the same process.
I have the same issues on my S7 edge. I have notifications shown on lock screen and allow gpm to show. I've even done a FDR without luck. The album art is displayed with a white background. Only when I hold my finger in the white background do I see the controls showing in black pop up but they don't stay. When the phones unlocked and you access the pulldown menu it doesn't display properly there either it's the same white with just album art no controls.When I'm playing music I have to unlock the screen to perform forward, etc. Is there a way to display media controls on the Samsung S7 lock screen?
P.
