Has anyone experienced jittery videos on QHD,FHD and UHD modes? The motion while taking the video is jittery.
Wonder if it is my SD card? Did not have the issue on S5.
Seems like people are not using video. Yes I tried device storage also.
The jitter is caused by the optical image stabilization. If you slowly pan the video and stop you'll see the camera continue moving just slightly to correct for the roll. As others have said the video plays back normally. I suspect the issue is a software glitch where the optical stabilization of the camera isn't allowing the phone's viewfinder to keep up. Shouldn't be an issue but likely will be fixed in an update I suppose?
Ok. But the stutter about every 3 seconds on the recording using fhd 60 fps is noticable and it ain't right. Hopefully, like you said, an update will fix it.
Okay, but it says nowhere? One should well expect that 60 FPS is 60 FPS regardless of movements?
Besides recording in the other qualities very poor by movement. Introduces very much motion blur. That does not happen in the 60 fps?
Alexander 10:31:54
There is, unfortunately, limitations of the phone, there's nothing we can do about it
Thomas 10:32:36
Can you detail some of the restrictions in question?
Alexander 10:33:23
The phone has a certain performance, if you try to do something that requires more, the phone does not catch
Thomas 10:34:17
But I do nothing that requires more, this is the default setting in the stock camera app on your phone?
Alexander 10:35:03
Yes, and it works as long as you do not make sudden moves
Thomas 10:35:40
So the conclusion is: You can do OK recording as long as there are no rapid movements in the picture?
Alexander 10:35:51
Yes
Thomas 10:36:02
Thanks for the information.
