Biggest Complaint So Far
KPMcClave
1,777
Not too much to ***** about with my S7E. I find it slightly uncomfortable to hold without a case (tooo narrow and hard to avoid touching the edges of the screen), but that's a minor quibble.
My biggest complaint is probably the tiny font on the notifications in the notification shade. What is up with that? Why is it so tiny? It's not just a personal preference thing, really, it borders on the ridiculous. Especially since there seems there is no way to adjust it.
I turned on my LG G4 this morning and the font in its notification shade is significantly larger and doesn't seem to sacrifice anything in viewable text.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
Does adjusting the size under Font change the text within that? I made my entire screen smaller to get more real estate but I don't have an issues reading the notifications.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
You can actually adjust it... Look in the s7 edge faq sticky. However you can only make it smaller (more condensed). I actually made it more condensed because I get a lot of notifications.
If you want to make it larger... Then you would need root.
KPMcClave
1,777
Changing the System font size doesn't do anything with that particular font.
KPMcClave
1,777
Smaller. LOL.
KPMcClave
1,777
Is this notification font size the norm for Galaxy handsets now? My daughter has a S3 and my wife has a S5 and I haven't noitced such a tiny font on their handsets.
munnarg
Trusted Member
Jun 20, 2010
507
4
I made mine smaller using the condensed text tweak. Now the phone actually looks like it's making good use of this beautiful screen real estate.
natehoy
2,667
71
Smaller. LOL.
Almost certain not to work but easy to try: I'd recommend trying to turn the compression on (save the setting) and then back off (save it again) to make sure there isn't some oddness that is misreading the setting and actually compressing it on you even though you never asked for it.
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
Interesting observation. I don't have the sharpest eyes in the world (I'm a long way from 30-something), but I have no issue with the notification fonts. I just looked at my G3, and there's no significant difference in the notification font that I can see.
My biggest gripe is that Lightflow just doesn't work 100% correctly. Or more accurately, when I set up lighflow so it works correctly in interferes with fingerprint unlock in some situations.
KPMcClave
1,777
Thanks, nate. You mean the Condensed DPI setting? I did try that (and thanks for the heads up everyone) and back and it doesn't change notification shade text. I prefer the Standard DPI anyway, as it turns out.
KPMcClave
1,777
Here are screenshots of my S7E and my G4. I'm not sure how this will translate in the screenshots, but the difference is noticeable:
...oh yeah, it shows.
Adiliyo
2,412
49
it's a normal size, LG has been using a MASSIVE font since the G3 and it's almost comically large.
edit:
if you are comfortable with setting up ADB, you can use this method to increase the DPI (raise the number) to make everything bigger
[GUIDE] How to change DPI without root | Samsung Galaxy S7 Edge
i'm not sure what LG uses, maybe 680 or something, the stock iirc is 640, so you'd want to pick a number larger than that to make everything look bigger.
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
I see what you mean now. I was looking at the header text in each notification, not the detail. I still don't have any real issue with it. If I want to know more than what the header shows, I click on the notification anyway.
KPMcClave
1,777
I'm pretty sure they don't both have the same DPI, so that could be it. Those G4 notifications look comically huge though.
My Droid Turbo also didnt have the tiny notification detail font.
They should adjust for DPI from handset to handset.
At the very least, this is something that should have a setting for it.
~Kevin
Adiliyo
2,412
49
~Kevin
android N will let users scale the DPI setting through the UI. until then you can use adb to adjust the DPI.
the OEMs do adjust the DPI for what they feel is good for the user, which is why you see the variation between them, DPI (in this sense) is not a function of the hardware, it's just a software setting.
tress
