Hey guys, new poster here. I bought an ATT S7E last Thursday and so far I have been enjoying it...
except that for the fact that there seems to be an issue with maintaining a connection with apps. Facebook, for example, will have an error that says "can't connect right now" so it wont auto or manually update the feed. Flipboard wont auto update and I need to close the app to update stories. Spotify will play a song then maybe cut out halfway through or the next song in the playlist wont start unless the app is open and screen is unlocked. The same issues apply to two different podcast apps. Also the weather widget app wont auto update either. Whether the phone is on WIFI or data does not make a difference.
Anyone have a clue to what's going on?
