New T-Mobile S7 Edge Update 5/4/16
erasat
2,590
I think they just activated the FM radio, but now we just need to download any FM radio app. I will try this later and will see what happens.
cd247
Active member
Oct 9, 2011
35
What is the best FM radio app for the Galaxy S7 Edge. Preferably one that uses the least amount of data
Galaxy S7 Edge: Silver Titanium
Dhawk1202
345
Preferably one that uses no data.... As in on the binge on program.
cd247
Active member
Oct 9, 2011
35
No, as in, can work in airplane mode or without wifi/mobile connection. I work in a dead zone building.
I have Binge on but doesn't help without a connection....
cd247
Active member
Oct 9, 2011
35
No, as in, can work in airplane mode or without wifi/mobile connection. I work in a dead zone building. FM radios work in the building.
robfil
6
You need to download a radio application such as Nextradio and you need your wired headphones plugged in to work as an antenna.
itsnotmeitsyou
598
^ this. And FM radio apps, such as NextRadio, work without a data connection. After all, that's the whole point of the FM transmitter. You can always stream local radio online.
erasat
2,590
I downloaded NextRadio free and it works very well with the headphones as your Antenna. I'm still looking for a simpler FM radio app, one that looks just like the OEM ones, just a plain tuner, but I think I'm asking too much, after a while I didn't find anything similar, so I just downloaded Nextradio.
mgm83
110
T-Mobile has new update. adds fm radio
Also added some fixes and stability improvement.. whatever that means..
cd247
Active member
Oct 9, 2011
35
Thanks. The headphones as an antenna seemed silly. I thought it was bs
dumpsterrentals38
