After 4 weeks of purchasing Galaxy s7 edge I have experienced same problem, and I have found a solution. It is a kind of workaround, but it works. Normally, I would send phone to Samsung to fix it, but I am so busy person that I do not have time for this, and smartphone is my working area, two weeks without it is a nightmare.
As you probably now, if you change the brightness to 100% it works fine, you do not see black/grey stripes, so what I did, I have used Twilight application to change screen settings. So in the system I have 100% brightness, and in the application I have following settings (sorry it is in Polish, but I believe everyone will figure out the settings):
http://images83.fotosik.pl/89/3162a5919d58a43cmed.png
With this configuration it works perfectly fine, and you will not notice something wrong is with the screen. Of course this solution is only for few weeks, because you still have broken phone, which finally needs to to be fixed by Samsung.
To be honest with you, Samsung for me is now going only for money, nothing else. What happened with Galaxy Note 7, they wanted to earn as much as the could, but finally the lost. What I think... Karma exist and Samsung noticed that.
