That's why I usually compare it with the device uptime. It helps to understand how the phone is being used.
If the SOT is pretty close to the device uptime, then the device has been used for quite a while. If it is lower compared to the uptime, it is likely used in a light manner.
Back to this for a minute. The new generation of processors from Qualcomm, Apple, Samsung and Huawei (maybe others that I haven't been able to try) are pretty slick.
They do everything they can to stay in a low-power state, and most times that's still plenty "powerful" enough to do smartphone things. But when they have to ramp it up, they get blazing hot and eat the battery like never before. There was a fellow in these forums who got a G5 early, and had some pretty amazing battery stats. Nobody believed him, even when he showed his data. Got me curious and i did some testing.
When apps like games are running, they eat more battery than they used to. Most other apps and services just sip the battery, including streaming video. The screen tech has been tamed, and backlighting on LCDs or RGB pixels on AMOLED don't eat battery like they used to. Most of this has trickled down to the last gen (810, 808 and last-years Exynos CPUs) as well, so a lot of it is software or kernel based.
This also create a new problem. When a runaway process keeps the CPU ramped on one or more cores, it eats way more battery than it normally should. Because we get used to the way normal processes are gentle on the battery, we notice it. It also makes the phones pretty hot, and even insulated glass back can get warm enough to make us concerned.
What we need to try to do to troubleshoot high battery drain is look at the apps that are running. Unfortunately, many of the problems are system services that are locked open, and show up as Android OS or System or Google Play services. Those three things do nothing on their own, and will have zero affect on the battery if something isn't using them. This is most evident on the GS7. If you shut off all the Samsung "stuff" your Android OS and system battery use will be close to zero. Turn it back on, and Samsung apps and the keyboard and the calendar and the address book and Samsung Pay put Android OS and System back at the top of the battery list.
It will take some smart people to figure it all out.
Also — how far off-topic can we take this thread? LOL Sorry OP.
