WiFi Calling Icon not showing AT&T
oasisbliss
6
I have a s7 edge with at&t with the latest update. 6.0.1
I am trying to enable wifi calling and the setting icon is not even there. I have tried going to phone/settings and there should be a wifi calling option right under the vibrate option, it is also not there. My wife has the exact same phone under my plan and hers works great so I know it is possible. Anyone have any info on this?
thank you
thecomicbookandme
264
It should be there. Check out my settings.
Make sure you have the latest AT&T update. Under settings>system>about device, your Android security patch level should indicate July 1,2016
Yea! Heavy And A Bottle Of Bread
oasisbliss
6
My security patch is May 1, 2016 - how do I update this? when I do the updates on the phone it says all are up to date... thanks
thecomicbookandme
264
You should have gotten the July update. That's why you don't have Wi-Fi calling.
Go to settings>system>about device>software update.
If AT&T is your carrier, the update is available.
oasisbliss
6
Thanks but again I did that and it shows I am current. I even tried doing an update with smart switch it says up to date as well.
any ideas ?
thecomicbookandme
264
Go to the closest AT&T service center and have them update it for you. You're two months behind on security updates.
Oct 13, 2016
6
U said i should have an update of security patch level of date july but mine is showing of 1 september 2016 but still wifi calling is not working on my samsung galaxy s7 edge.
Oct 13, 2016
6
I am opening phone settings by clicking settings> application>phone
But there is no option as wifi calling.
But it is showing the option in notification panel..
And its not working..
thecomicbookandme
264
Go into the phone app. Select "more" upper right corner. Select "settings". Scroll down to "wi - fi calling".
This has nothing to do with the OS settings.
If the selection is not available, it is probably due to your carrier.
