Permanent fix to Battery Drain.
shoaib shah
423
Hi
As you all know most Android devices inevitably have to suffer from the Battery Drain coming from the high percentage usage of the Android System or Android OS showing in the battery stats.
I am also suffering the same with my s7edge. I know rebooting or factory resetting fixes it but temporarily.
Is there a permanent fix to this problem.
Thanks in advance
Bleezy
86
11
If there was an answer to this, we'd all know by now. Ive researched various sites and there isnt a clear answer. All you can do is disable the bloatware, and turn off everything you're not using (wifi, blutooth, gps, etc) and close out the apps running in the background when you're done using them. There isnt very much beyond that.
Jdroids
440
7
Make sure to keep location history and improve accuracy turned off under location setting. That's one of the biggest hitter for stand by drain. Doing so wouldn't hinder use of map or any location based service.
access101
11
Get package disabler pro from the play store and use the menu to select disable bloatware. Also disable qualcomm.atfi. this made my battery life rock!
KPMcClave
1,777
Sorry qualcomm.atfwd. it is a TV mirroring service. Ate a lot of my battery. I don't use it.
That is one of the packages that runs regardless of being disabled, though (go check it on the More tab of EZ Disabler...it will be running). The thought a while back when we were discussing this in another thread was that those packages that run anyway seemed to use more battery when disabled. I enabled any that insisted on running regardless of active status.
RandyRoyalty
