You can download one from the store while waiting for an update.
Yes. Well I think it does. I have a paid version so that feature is available. Can't remember if it's available for the free version. It's called Twilight. Has a red circular icon with a setting sun drawing.
Does the filter simply come on and off, Or does it gradually come on and gradually come off??
It can do gradual. Tap the 3 dots on the bottom of the screen (you may have to scroll down) and get to 'transition time' to adjust how fast it reaches the full intensity that you set.From what I've noticed it just comes on, not like Samsung's implementation, where it's gradual based on time and light situations. But I've only had it for 1 night so I'll see this evening.
The sunset/sunrise setting is included for free. The pro version gives you access to more than 2 profiles as well as sunset/sunrise offset and transition time.Twilight is a good app. The automatic sunset/sunrise settings is a paid feature. The scheduling at fixed on/off times is free (I think). You can even block the notification panel for Twilight so it is completely set and forget like the Note 7 feature.
