Gear VR and Oculus
freeop
24
Just got my Gear VR Headset and followed all the steps to get it working. Plugged the phone in and got the GEAR VR Software download screen. Now all it does is it shows "Update Required" and shows Oculus System Activites and "Update Now". I have done the Update Now like 20, 21, 22, etc. Times now and still shows it downloading then back to the Update now.
I have also uninstalled Oculus completely and plugged the phone back in and it started downloading Oculus again. All 100.4MB. and it now continues to want to Update over and OVER again.
What am I doing wrong? I can't get any further than that.
SpookDroid
Ambassador
Jul 14, 2011
19,302
555
113
Not sure if it'll help, but are you on WiFi? For some reason mine didn't want to update unless I was on WiFi, but mine didn't even let me download, let alone install.
freeop
24
Yes sir. I am on WiFi and thought if I disconnected from WiFi and tried to download via the 4G LTE Network that would help. But only thing that changed was the speed that it took to download the update.
Reconnected WiFi and same thing. "Update Now" just stuck in a continuous loop and can not do anything with the Phone or Gear VR together. Is there any where to download the Gear VR Package or the Oculus update? This is getting me nowhere as it is stuck.
freeop
24
Well finally figured it out. I did a search on the Oculus Site under the Support/Gear VR section and was reading a post that was exactly like my problem. On about the third or forth reply someone mentioned that if you had an app blocking anything from FACEBOOK, it would not load as Oculus uses the Facebook servers for their downloads.
Well I had disabled all the Facebook cra... Um services on my phone so nothing was getting through. Once I reinabled all the Facebook stuff, it worked and it finally finished the download and installation of the Oculus software.
So everything is working now, just because of Facebook. Makes no sense to me, but it works.
Non
