Can you recommend me a wireless charger for the S7 Edge? I see different versions on Amazon - a standard one and S7 "Fast" one. What is the difference and which one should I use for the S7 Edge? Also, will wireless charging work if I use the Spingen case on the phone?
Edit: I ordered the S7 Fast charger. I think it will work with my S7 Edge. However, is there danger from ordering from Amazon? If the device doesn't turn out to be legit (if the seller is unreliable), can it damage my phone or its wireless features or it will be safe? Thank you.
