Hello,
Thinking about finally swapping my Note 7 for an Edge 7 or V20. I was thinking I might go with the Edge as it's so similar to the Note.
I really like the screen and build, not a oil and finger print magnet like other cells I've owned. Also a fan of the amoled screen, and like that the Edge also fast charges and is water resistant. I do like the larger screen size of the Note, which is one drawback from the Edge and a reason I've considered V20. I was curious about getting some input from others who went from the Note to the Edge. Few questions,
Did you get used to the smaller screen after using the Note?
Is the screen actually 5.5" or slightly smaller realstate like ive read, than say IPhone Plus display due to the more profound curved Edge screen ?
The Edge screen is a bit more curved than the Note, I noticed looking at an Edge display once a kind of fish bowl effect viewing web pages.
Is this effect something you get used to or does it make certain things awkward ?
Aside from smaller screen, internal memory, no S pen or C-charger, are there any other big differences that I might not realize ?
Thanks for any replies, greatly appreciated. Torn between the similarity of Edge after having a Note that I love, versus V20 as I really like the 5.7 display. I just love the Samsung amoled screens and how resistant the screen seems to oil, dust, stuff like that. Can't decide to settle for smaller screen but very Note like or same size with V20 but a screen and color balance that is a big disappointment.
