Hi all, this morning I awoke to find my S7 at 87%. I took it off charger just before I went to bed. Obviously this is not right. This thing should be dozing the night away as it's running Marshmallow. What could be the issue here?
Hi Cakefish! It seems a lot. Can you get the signal bar after you tap on the battery graph? Maybe some problems with your network?
Maybe the S7 doesn't include that option. This is what I get when I tap on the main battery graph.
Have you used Package Disabler Pro to disable a bunch of apps?Hi all, this morning I awoke to find my S7 at 87%. I took it off charger just before I went to bed. Obviously this is not right. This thing should be dozing the night away as it's running Marshmallow. What could be the issue here?
//uploads.tapatalk-cdn.com/20160407/fdad440f9ed2df2d81011ae07a8df9b0.jpg
No, I mean mine is an unlocked model so has no carrier bloatware. Which apps should I be disabling? The phone comes with some Microsoft apps preinstalled and that's about it.Have you used Package Disabler Pro to disable a bunch of apps?
Unfortunately that's not possible on Samsung devices for whatever reason.
I've installed the app. Will see what it says after I've given it enough time to calibrate.You could try Gsam to get that kind of charts.
Its the app from the Policedeveloper right? Does it work really?
Yes, it works for non rooted phones. It allows you do disable pretty much any app you want. Not uninstall it but just disable it.
Does it disable apps for all time, or just for a short term?
Nothing happens that I know of. I have accepted them with apps disabled and everything went just fine.Speaking of Package Disabler Pro, I read somewhere you have to re-enable apps before accepting an OTA. Why is that and what will happen if I don't? (Off-topic I know, but I have to ask)
